You can view a brief or detailed output of the port channel of all tenants, a given tenant, or a given port channel.
efa tenant po show [--name po-name|--tenant tenant-name | --detail |-- help]
+--------------------------------+-------------+---------------+ | State | Dev State | App State | | | | | +--------------------------------+-------------+---------------+ | po-min-links-count-set-pending | provisioned | cfg-refreshed | | | | | +--------------------------------+-------------+---------------+ | po-delete-pending | provisioned | cfg-refreshed | +--------------------------------+-------------+---------------+ | po-port-delete-pending | provisioned | cfg-refreshed | +--------------------------------+-------------+---------------+ | po-created | provisioned | cfg-in-sync | +--------------------------------+-------------+---------------+ | po-lacp-timeout-set-pending | provisioned | cfg-refreshed | +--------------------------------+-------------+---------------+ | po-description-set-pending | provisioned | cfg-refreshed | +--------------------------------+-------------+---------------+ | po-mtu-delete-pending | provisioned | cfg-refreshed | +--------------------------------+-------------+---------------+
$ efa tenant po show --detail ===================================================================================== Name : po1 Tenant : tenant11 ID : 1 Description : EFA Port-channel po1 Speed : 100Gbps Negotiation : active Min Link Count : 2 Lacp Timeout : short Ports : 10.20.216.15[0/12-13] : 10.20.216.16[0/12-13] State : po-created Dev State : provisioned App State : cfg-in-sync ====================================================================================== ====================================================================================== Name : po2 Tenant : tenant11 ID : 2 Description : EFA Port-channel po3 Speed : 10Gbps Negotiation : static Min Link Count : 1 Lacp Timeout : Ports : 10.20.216.15[0/15] : 10.20.216.16[0/15] State : po-created Dev State : provisioned App State : cfg-in-sync ====================================================================================== ====================================================================================== Name : po11 Tenant : tenant21 ID : 3 Description : EFA Port-channel po11 Speed : 25Gbps Negotiation : active Min Link Count : 1 Lacp Timeout : short Ports : 10.20.216.15[0/22] : 10.20.216.16[0/22] State : po-created Dev State : provisioned App State : cfg-in-sync ====================================================================================== --- Time Elapsed: 506.117046ms ---
$ efa tenant po show --tenant tenant11 --name po1 +------+----------+----+---------+-------------+----------+---------+ | Name | Tenant | ID | Speed | Negotiation | Min Link | Lacp | | | | | | | Count | Timeout | +------+----------+----+---------+-------------+----------+---------+ | po1 | tenant11 | 1 | 100Gbps | active | 1 | short | | | | | | | | | +------+----------+----+---------+-------------+----------+---------+ +---------+--------------------+------------+-------------+-------------+ | Lacp | Ports | State | Dev State | App State || Timeout | | | | | +---------+--------------------+------------+-------------+-------------+ | short | 10.20.216.15[0/12] | po-created | provisioned | cfg-in-sync | | | 10.20.216.16[0/12] | | | | +---------+--------------------+------------+-------------+-------------+ PortChannel Details --- Time Elapsed: 150.30883ms ---
$ efa tenant po show --tenant tenant21 --detail =========================================================================== Name : po11 Tenant : tenant21 ID : 3 Description : EFA Port-channel po11 Speed : 25Gbps Negotiation : active Min Link Count : 1 Lacp Timeout : short Ports : 10.20.216.15[0/22] : 10.20.216.16[0/22] State : po-created Dev State : provisioned App State : cfg-in-sync =========================================================================== --- Time Elapsed: 223.892847ms ---
